Продолжаю список своих недавних покупок на Али.
101. Наклейки OPEN http://ru.aliexpress.com/item/8pcs-2-pages-lot-2-colors-Car-Door-OPEN-reflective-stickers-warning-sticker-car-necessary-choice/903003121.html?detailNewVersion=2
102. Очки ночные http://ru.aliexpress.com/item/Brand-New-Night-Driving-Glasses-Anti-Glare-Vision-Driver-Safety-Sunglasses/1616846458.html?detailNewVersion=2
103. Душ насадка http://ru.aliexpress.com/item/1Pcs-Universal-Handheld-Chrome-Water-Saving-Pressure-Rainfall-Square-Nickel-ABS-Hand-Held-Shower-Head-Handshower/32293071382.html?detailNewVersion=2
104. Крокодильчики http://ru.aliexpress.com/item/10pcs-red-and-black-28mm-PVC-Insulated-Crocodile-Test-Clip/1671277180.html?detailNewVersion=2
105. Цеплялки http://ru.aliexpress.com/item/New-Multi-color-10-Pcs-Mini-Single-Test-Hook-Clip-Test-Probe-for-Electronic-SMD-IC/32491143209.html?detailNewVersion=2
106. Фрезы http://ru.aliexpress.com/item/New-6Pcs-Abrasive-High-Speed-Steel-Rotary-File-3mm-6-Different-Files-Gravor-Wood-Carving-Milling/32532092590.html
107. Бананы http://ru.aliexpress.com/item/Free-Shipping-10pcs-Black-Red-Wire-Audio-Speaker-Cable-Banana-Plug-Connectors-4mm-Adapter/32450255590.html?detailNewVersion=2
108. Термоклей http://ru.aliexpress.com/item/Single-package-silicone-thermal-plastic-radiator-adhesives-grey-60g/1762926479.html
109. Подсветка в дверь http://ru.aliexpress.com/item/12V-7W-Reverse-Sensor-Laser-Eagle-Eye-Auto-Car-Door-Light-LED-Waterproof-DRL-for-Toyota/32231582747.html?detailNewVersion=2
110. Светодиоды http://ru.aliexpress.com/item/5pcs-5mm-colorful-pre-wired-20cm-LED-light-12V-with-Plastic-Bezel-Holders-red-yellow-blue/32323513066.html?detailNewVersion=2
111. Разъемы 2к http://ru.aliexpress.com/item/10pairs-lot-LED-strip-Connector-2pin-cable-Terminals-red-black-Wire-Male-female-plug-cable-Led/32478945790.html?detailNewVersion=2
112. Микрофон http://ru.aliexpress.com/item/FA-MT01-6-12VDC-Microphone-Pickup-Aerial-Audio-Signal-Collection-For-Camera-FPV/32609871591.html?detailNewVersion=2
113. Сифон для аква http://ru.aliexpress.com/item/Siphon-vacuum-water-pump-gravel-cleaner-aquarium-filter-clear-tool-55/32549718896.html?detailNewVersion=2
114. Скребок аква http://ru.aliexpress.com/item/New-Arrival-Low-Price-45-65cm-Aquarium-Fish-Tank-Glass-Stainless-Steel-Algae-Scraper-Blade-Cleaner/32515333555.html?detailNewVersion=2
115. Габариты светодиодные http://ru.aliexpress.com/item/4PCS-6-LED-Car-Truck-Trailer-Side-Marker-Indicators-Lights-Lamp-12V-Red-Hot-Selling/32557910775.html?detailNewVersion=2
116. Свет багажник http://ru.aliexpress.com/item/100-Waterproof-2Pcs-COB-LED-Lights-DRL-Daytime-Running-Light-Auto-Lamp-For-Universal-Car-hot/32605367394.html?detailNewVersion=2
117. Адаптер OTG http://ru.aliexpress.com/item/Android-Robot-Shape-Micro-Mini-USB-OTG-Adapter-Cable-For-Tablet-PC-MP3-MP4-smart-Phone/32395878889.html?detailNewVersion=2
118. I2C http://ru.aliexpress.com/item/Free-Shipping-IIC-I2C-Interface-LCD1602-2004-LCD-Adapter-Plate-for-Arduino/32501201303.html
119. LCD2004A http://ru.aliexpress.com/item/Free-shipping-LCD-Board-2004-20-4-LCD-20X4-5V-Blue-screen-LCD2004-display-LCD-module/32555852972.html
120. Провод макет(мама) http://ru.aliexpress.com/item/Dupont-Wire-Female-to-Female-Cable-Line-40P-40P-Test-Lines-Connector-10cm-for-Arduino/32586065496.html
121. Платы SOP8/TSOP8 http://ru.aliexpress.com/item/10PCS-SOP8-SSOP8-TSSOP8-to-DIP8-Interposer-Moudle-PCB-Board-Adapter-Plate/32334961671.html
122. Micro USB (30см) http://ru.aliexpress.com/item/High-Quality-30-cm-Full-Copper-Mini-Usb-Cable-Micro-USB-Charging-Cable-for-Samsung-galaxy/32404354309.html
123. Attiny13A http://ru.aliexpress.com/item/Free-Shipping-8-bit-Microcontroller-with-1K-Bytes-In-System-Programmable-Flash-ATTINY13A-SSU-NEW-Good/32521978372.html
124. P21W http://ru.aliexpress.com/item/High-Quality-P21W-1156-BA15S-10-SMD-5730-CREE-Super-Brightness-Brake-Parking-Reverse-Lights-Fog/32396339030.html
125. Датчик движения (220в) http://ru.aliexpress.com/item/1pc-Hot-Newest-200W-220V-IR-Infrared-Module-Body-Sensor-Switch-Intelligent-Light-Lamps-Motion-Sensing/32552581917.html
126. USB-лампа http://ru.aliexpress.com/item/Touch-Dimmable-Flexible-USB-LED-Eye-care-Reading-Light-Adjustable-Solid-Clip-Desk-Lamp-for-Laptop/32486076678.html
Посетитель Москва, Центр Сообщений: 356 |
Посетитель Жуковский М.О Сообщений: 263 |
Evgeny-SK, Блин ну клево же все расписано!!!Все по полочкам ![]() ![]() Кстати светодиодика оранжевого 3мм нет случаем лишнего у кого?оплатил бы доставку почтой или кину на телефон,ждать влом,да и поштучно непродают. ![]() Редактировалось: 1 раз (Последний: 5 мая 2016 в 23:45) | ||||
Evgeny-SK, Они самые родные ![]() ![]() | ||||
Взял бы желтый и красный,чтобы было что то похожее на нашу подсветку,для этого,хочется себе внедрить: http://www.lada-largus.com/blogs/kak-snjat-blok-predohranitelei/podsvetka-zamka-zazhiganija.html | ||||
Понятно... ![]() ![]() Редактировалось: 1 раз (Последний: 6 мая 2016 в 00:20) | ||||
Evgeny-SK, за так немогу,с меня пиво!с тебя телефончик в личку ![]() ![]() | ||||
Видел оранжевые(янтарные),только квадратные маленькие, даже где-то на даче валяются, могу в эти выходные посмотреть если надо... ![]() Я, кстати, себе синюю поставил на замок и в ноги тоже. Другие цвета не смотрятся. Редактировалось: 1 раз (Последний: 6 мая 2016 в 00:34) | ||||
Bitali4,А чем готовые кружки подсветки замка на Али не устраивают? ![]() | ||||
Повышающий dcdc c Али, выдает 27.5-28В. Использую для запитки 3*10вт светиков в режиме по 2-3 Вт на каждом, около 0.2-0.3А. В этом режиме dcdc чуть теплый, думаю в паралель 2-3 ветки по 3 Светика в каждой он потянет спокойно, без сильного нагрева. Доволен, рекомендую. В работе бесшумен, т.е. не свистит.. 5 шт. MT3608 DC-DC применить модуль усилителя модуль питания максимальная выходная 28 В 2A http://s.aliexpress.com/qANjU7Bj (from AliExpress Android) На фото 3 Светика 10вт ных включены последовательно: Использую потому как БП на 28-30В регулируемые очень дорогие, а все на 12В делать - будут большие токи на проводах (0.5-0.75мм у меня - больше 3-4А нежелательно через такие провода гнать, греться будут). А использование опорных 12В дает возможность организации освещения аварийного - при отключении электричества свет будет всегда (12В 4А аккум аккумулятор на пару часов хватит, или от авто провод брошу, разъем под капотом уже поставил). Редактировалось: 4 раз (Последний: 6 мая 2016 в 07:52) К7М+ГБО+чип Паулюс евро2, 9 тык/год, 80% трасса, даче-мобиль. ![]() | ||||
Испытал фонарь на ночной рыбалке. Могу смело рекомендовать: фонарь налобный Светит просто зашибись! Лёгкий, на голове не чувствуется. Развесовка хорошая. Батарейки стандартные - 3хААА. Единственный нюанс - при отмахивании комаров перед фейсом ВКЛЮЧАЕТСЯ! ![]() | ||||
![]() ====================================== Получил бокорезы с кетаяндии .. трекались довольно шустро вплоть до москоу- потом ТИШИНА недели на 3 и вот ВАМ - кинули в почтовый ящик (вместо того - как оформить его себе - как БОНУС за двухнедельный трудовой стаж на Рашенпочтен ![]() ![]() ========================== Собственно фоты ..крокодильца + Попробовал "кусануть" ... Неа... Не золото ! В самой нужной , первой пятой части от носа - кусает неважно .. Виден на концах "перекал" от заточки . Пеньки желтолицые.. Вот у мя были "подаренные" с секр.завода бокорезы немецкие - это ПЕСНЯ ! Но у них - выросли ноги... ===================================== Наколку не даю - потому ,что фуфел - но когти неплохо рубит ... Редактировалось: 1 раз (Последний: 7 мая 2016 в 18:50) Нас невозможно сбить с пути, нам похеру - куда идти. | ||||
RENAULT KAPTUR 1,6л. H4M 114л.с и DUSTER 2 с 21года, 1,5L. K9К, 109л.с. | ||||
Пошел за одной посылью - а выдали аж 3 ... ![]() фитосветики с драйверами с ебея (на али почему-то дороже процентов на 25-30) конвертер HDMI на VGA + звук (тоже на али - дороже, брал на Ebay) Блок питания для диодной ленты 4А Нас невозможно сбить с пути, нам похеру - куда идти. | ||||
Но мои-конструктивно-не такие. Без кабелька-блок просто со входом-выходами. и разъемом питания 5 в. Редактировалось: 1 раз (Последний: 11 мая 2016 в 17:51) За рулем давно | ||||
![]() Когда покупал..а понравился он мне именно 4:3 - эйчдимиаем не грузился , а щас думаю приконнектить его к смартТВ приставке (еще не покупал) ===== Мля, никак шнура не найду vga .. кудой я его засунул? ![]() Нас невозможно сбить с пути, нам похеру - куда идти. | ||||
boris55, Проверил - работает . ![]() Аудиошнурок тока пришлось перепаять на "тюльпаны"... Нас невозможно сбить с пути, нам похеру - куда идти. | ||||
заодно слазил в "паутину пацстоломную" - сравнить БП али 4А с родным Хетачии ... Хетачеевский заметно больше (в полтора раза на вскидку), но и ток у него 5.2А на 12в, засумлевался за "жизнедолгость" кетайтса с али , справедливости ради- Хетачей - тож оттуда ![]() Редактировалось: 1 раз (Последний: 12 мая 2016 в 18:41) Нас невозможно сбить с пути, нам похеру - куда идти. | ||||
Я бы с запасом брал... Мой 5а (12в) подобный БК с Али сдох в связке с 20инч теликом хундаи(2005 г.в., 640*480 ) А 10А БП тянет на ура и почти не греется.... ( тоже с Али, только он в металл корпусе с дырками и клемами под 220 и 12) К7М+ГБО+чип Паулюс евро2, 9 тык/год, 80% трасса, даче-мобиль. ![]() | ||||
mumrik75,
на кетайскую ленту 35х28 (думаю сдвоить ).... В ванной комнатке СДВОИЛ- ваще комильфо ! --------------------------- Другая тема всплывает .. Где продают СЕЙЧАС алюминиевые уголки (для теплоотвода) ?? ![]() Нас невозможно сбить с пути, нам похеру - куда идти. | ||||
2 брат, К коментариям ценник пиши еще,для полной информации. 2012г.в.Люкс 104кобылы.5я-756, пропан :Томасито, мозги дижитроник, форсы диижитроник.Баллон 50л.в салоне.пробег 180 тыс. | ||||
Ты думаешь ...это комунибудь нужно ? =============== Напишешь ценник- начнут троллить- лошара типа - я купил дешевшее на пол-чатла ![]() Нас невозможно сбить с пути, нам похеру - куда идти. |
